Hi all,
Noob here. I did a pretty decent test print using Cura with 0.15 mm layers, and wanted to make it a little finer--adjusted layer thickness to 0.1 mm and changed nothing else. For some reason when I slice it, the preview shows up empty: about 4 hours of print time (which sounds about right) but 0 layers. The G-Code only shows the "Generated with Cura" header, and is otherwise blank. Any idea what is going on here?
Cura slicing returns 0 layers
- lightninjay
Re: Cura slicing returns 0 layers
My best guess would be to check your model and make sure it's manifold and/or thick enough for your nozzle to extrude layers for it.
I've found that if the model I'm trying to slice is too small or too thin, Cura won't even generate layers for the areas which are too thin.
Stryder502
- Noob
I have the same issue, except that its generating 0 layers for every file.
I have a RoStock Max V2 and am trying to use the files that I downloaded with it.
