Polygonhell wrote:I can't remember how the H1 hotend is mounted, but you will minimally need some sort of adapter if you go with any hotend that isn't like the original. You might want to take a picture of the existing mount and post it here. Usually I'd print an adapter, but you'll have to be more inventive.
Yeah, I'm thinking of using plywood, and just cutting it to shape. Sure, I'll post some pictures.
Here's what I've been able to scour from the 'nets:
SeeMeCNC H-1 Hot End
Extruder Barrel Assembly
Hot End Holder
Groove Mounting Plate for E3D-V6 (plastic)
Groove Mounting Plate for J-Head (aluminum)
Polygonhell wrote:I also wouldn't spend a ton of money on something like an E3DV6, to print most of the high temp plastics you'll need a heated bed, the E3DV6 Lite is certainly an option, I'd also consider an original JHead.
I have a heated bed. -- I can only get it up to about 90 degrees C (due to convection cooling, it will get hotter if covered, but cools rapidly), but I think if I up the voltage, I should be able to get it hotter and sustain the heat.
Is the E3D-v6 a J-Head type? -- What do you think of the J-head at hotends.com? -- It looks like it uses the same mounting bracket as the E3D-v6 -- is that a common mounting style now? Are there dimensions available somewhere? -- Is this how all the hot ends are, or ...? -- I'm not seeing many other styles -- everything seems to just have a lip at the top and slide in or so?
The bottom mounting plate for Steve's Extruder has two posts with captive-nut indents that are available for hot-end mounting. The minimum you need to make is an appropriate plate that has a U-slot for one of the matching slots on the hot-end and screw-holes for those posts. Yes, it can be made out of wood if you want. Search for "j-head mounting plates" for various images of what I'm talking about. Or you can buy one of the commercial plates and drill new holes if required.
I think you're right -- though, I'm worried, it might sit too low there (that's kind of the close to the bottom of the normal print head, and it would be the top of the J-head right?) -- with my heated bed, I think that will give me even less Z-axis... -- but, it might be the way I gotta go... -- if I do it that way, I think the only thing I gotta worry about is fitting everything in between the bars that the X gantry slides on....
I wonder... maybe I can make an adapter that goes there... but has a block of wood that comes up -- and the plate the J-head slides into can sit higher.... that might work.... -- need to make sure a fan can still cool it... but, I think I'm on to something here... this could work.
EDIT: Scratch that -- Those screw joints don't actually come all that low, they're pretty snug against the main plate -- I guess all I would need is an extended teflon tube for my new hotend. Here take a look at these pics I just took (can't find the model, sorry):
H-1 X-Gantry Plate.
EDIT 2: Found some dimensional drawings of the J-Heads / Mounting Plates:
J-Head Mounting Plate Technical Drawings with Dimensions.
Also, this adapter looks pretty cool -- maybe after I get something going with wood, I'll print a new X-gantry plate that the J-Head just fits into, and doesn't even need an adapter -- something like this could be cool:
J-Head plate mounting hot end prusa mendel.
