Hey everyone,
I just updated to the recent version of Repetier and was trying out Cura for the first time. When I start a print that I uploaded to the SD card, I for one get errors while uploading, and two, when I start the print from the SD card it just very very slowly moves down along the z-axis. Does anyone have any advice on how to get this working? Is there something in the Cura Gcode that I should change? I saw there was a custom code in there for z-axis speed that didn't really seem like it needed to be in there.
Latest Repetier and Cura Issues
Re: Latest Repetier and Cura Issues
I use Cura standalone and haven't had that issue. Sometimes using it nested inside of Repetier is a blessing and sometimes it's a curse. It wouldn't shock the heck out of me if Repetier is trying to push data from your printer settings into Cura. I'd look there first.
My start GCode is "stock" Cura minus one little part of the G28 line (it moves to x0y0z0 which isn't where a delta homes to, plain old G28 without coordinates works fine).
Is there anyway you can post your settings? Screenshots or something? Gcode as well. The Gcode on mine is what came stock with the new version of Repetier.
