Hi,
I would like to use the stand-alone feature of the Rostock MaX V2 but there must be something I did bad.
I copied some STL files on a SD Card and inserted it in the printer. Using the display and the knob I can select the file I want and when I press "enter", I hear 3 short beeps and nothing happens. What should I do next? Was it the right way to copy the files? i am under the impression that none of the settings made in matter hacker were exported. Any help would be appreciated. Thanks
Serge
SD CaRD Stand-Alone
Re: SD CaRD Stand-Alone
The printer will only recognize the gcode files generated by your slicing program, not stl files.
Very Nice, it is working fine. Thanks.
