So I popped a fuse and decided that as long as I'm pulling the RAMBO out, I might as well re-do some of the wiring to make it neater. Add to that the new fans I have to hook up (80mm push/pull, and a tiny 40mm on a heatsink for the extruder).
I'm curious if anyone would be willing to share how they handled wire management in that rats nest or any best-practices in wire routing to provide max air-flow through the base.
I accessed the bottom by loosening the bolts and lifting the entire top-panel of the base up - it slides right up the towers and sits at a slight angle, providing easy access to the innards. Might actually end up doing some other fixes while I'm in there
