redoverred wrote:Even if they are all high opposite the towers? I guess I'll have to fool with it a bit, but even after reading this whole thread and others it just seems like people are randomly moving things around until it fits. Is there even any math involved or steps to take to fix this in some sort of logical manner? Either way I guess I'l mess with the rotations a bit.626Pilot wrote:It's not pointless. Tower angle and radius offset can both have an impact on that. The printer thinks its towers are somewhere they aren't, and that's what causes that problem. If it only knew where they really were, it would lay down a perfect 1st layer every time.
The issue is how to check, change, and verify with the same repeatability in order to gauge if the changes made an acceptable difference. That's the hard part without probes and/or an exact method to follow when first getting into this "sport" of chasing down precision. I went through 3 carpenter squares only to realize I wasn't getting the towers square enough to the bed in a single axis. The manual doesn't explain how to correct any left/right lean to the build table at each tower. It wasn't until I bought a digital angle finder that I was able to measure and verify front to back and left to right lean on each tower. The next issue I'm working on is the tower rotation, how to measure and correct the actual tower twist is proving harder with manual loots and my lack of experience.
I've graduated from a piece of paper to feeler gauges to adjust the nozzle height. Although, you can get a good idea on how far each nozzle is off by taping a piece of paper down to the bed and run all 4 macros to press the nozzle to the paper. Measure the center of each towers nozzle impression to the center of the bed nozzle impression. In a perfect world those three numbers would be exact, and I believe that would show a perfect rotation??. It helps to have a little oozing filament to make the marks visible.
Anyway, what these folks are doing above are way above my level, I'll just continue to manually tweak and test to the best I can until then.
