100% agree unless it is a dedicated print server on an EXTREMELY stable computer. Growing pains in the beginning of 3D printing made me find that out the hard way with dozens of failed prints. Now I print with a mix of SD card and Raspberry Pi print server running Octoprint.JFettig wrote:I cannot emphasize this enough - PRINT OFF OF THE SD CARD WITH NO COMPUTER HOOKED UP!
You don't seem to understand that he's talking about a design that he sells. He has made these exactly to his design and there are other slicers that have produced exactly what he wants and what his customers have come to expect. The design is locked, the slicer must produce what he's already attained.JFettig wrote:When you design something to be machined and you're programming it and realize that if you did something slightly different it would be so much faster and better? It happens to me all the time. Same with printing, I'll draw something, slice it, look at the layers and see something I don't like so I go back and tweak it to make it better. It's just part of the game in my opinion.
Yes it is a software bug or flaw, its an easy one to work around
KAS wrote:I believe this is one of the issue in the slice pathing. 1 perimeter I believe is correct, but you can see what happens when 3+ perimeters are added.
Yeah from the photos with the arrows you had placed on page 2 I thought you were having issues related to transition between layers, but the issues shown on the previous images is OFC completely unrelated to that, and having used S3D for the last year, there really is no setting to change the way perimeters are slicedmhackney wrote:Micael, no printing is necessary to test this - it is a slicer issue and you can see the problem in the rendered gcode, no need to print. It's been verified now that this exists in 2.2.2 so no need for spending more time on this.
