Hot End stepper motor not feeding plastic
Potatohead908
I am still in the process of setting up my MAX V2. Everything has worked as it should to this point in the instructions up to this point. I can move the stepper by hand with the power on so I'm thinking it doesn't have power. This could be a wiring issue or a fuse issue. I will look into the wiring tonight when I get home. Is there any other things I should look at? Again everything else has worked up to this point in the instructions. I have calibrated the axis and am almost ready to start printing.
Potatohead908
Re: Hot End stepper motor not feeding plastic
Simple fix. I skipped two sockets instead of one when I connected the stepper to the board. Ooops!
Hey, at least you got it fixed!Potatohead908 wrote:Simple fix. I skipped two sockets instead of one when I connected the stepper to the board. Ooops!
Potatohead908
Yes!! It is now officially ALIVE and COMPLETE!! The first thing my oldest son asked me to print was too big!! Go figure!Eaglezsoar wrote:Hey, at least you got it fixed!Potatohead908 wrote:Simple fix. I skipped two sockets instead of one when I connected the stepper to the board. Ooops!
