Your not going to get the weight down to 1000 lb. The tesla, which does not have a 300hp gas motor or a Megawatt of total electric motors weighs in at 4650 empty, add two adults and your getting near 5000 lb, without any of the parts to make it fly, or any of the 300hp gas motor stuff. And the Tesla has an aluminum frame to save weight.Generic Default wrote:I'm glad you noticed the math too! I wouldn't call them inventors since they made a relatively low quality animation of a flying car. Most attack helicopters have two turboshaft engines, each providing around 1500 to 2500 horsepower. They use two in case one fails or gets blown up ect.
A flying car, assuming it's unarmored and made from carbon fiber or glass fiber (instead of cannon-proof glass and sheet metal) would need a lot less power to stay in the air. For quadrotors and small RC aircraft that don't have efficient wings, you need about 1 watt of power per ounce of weight. Which is convenient for us, just multiply the weight of the flying car in pounds by 16.
Assuming similar efficiency, a 1000lb flying car would only need 16,000 watts to hover, which is surprisingly do-able. A regular hydrocarbon fueled engine and tank would be more than capable of powering a lightweight flying car for hours at a time. The power not used for downward thrust could be used for forward propulsion (assuming the car has that). At higher velocities, wings could increase the efficiency.
Does my 16,000 watt estimate seem reasonable? I got the watt-per-ounce estimate from known values of power consumption vs weight in quadrotors. It just seems like a small amount of power needed to make something fly.
I would go by their number of 1 Megawatt required to fly, seems on par with a civilian helicopter. Your 16kW number /1000 lb ( 80kW for 5000 lb) still seems low - you could maybe get it in the air if it has big wings and that much power, but forget the vertical takeoff and landings.
