Cura Not Generating Supports
Talk about Cura software here (http://wiki.ultimaker.com/Cura)
Robaire
Post by Robaire »
I'm using the Cura slicer within Repetier, however Cura refuses to generate overhangs for specific parts of a piece. Both over hangs are parallel to the print surface, but at different elevations. My current hypothesis is either the overhang is too small for Cura to generate support for, or because it is on the outer edge Cura doesn't know how to generate the support. Has anyone run into this issue/ know what could be causing the problem?
Current Settings
Current Settings
Here Cura is generating the support structure just fine.
This is the overhang Cura refused to generate support for.
No Support.PNG (64.37 KiB) Viewed 13448 times
Renha
Re: Cura Not Generating Supports
Post by Renha »
What Cura version?
3D printing is magic!
Change your overhang angle, I bet that's it. You should have it set somewhere more like 45 degrees. Whatever angle you start getting sags is the same angle that you want the support to start.
Robaire
Post by Robaire »
No matter what overhang angle I use it refuses to generate the support material.
Can you post the STL? Something is fishy.
Robaire
Post by Robaire »
Yeah sure, here is the stl file.
Swerve Pulley Interface.STL
(190.32 KiB) Downloaded 467 times
Return to “Cura”
