Why am I getting this line thru my print? It just started happening.
False line keeps printing??
				Potatohead908
[img]http://s23.postimg.org/iffg6cpl3/IMG_20150814_193926_644.jpg[/img]
Re: False line keeps printing??
Do you see it in the software?
Mind posting the g-code for that print?
				Potatohead908
Nope. It only shows on the print.
I downloaded Slic3r and just print via SD card. Same STL's and no false line.
If I understand this correctly, your old slicer is what was causing the problem?Potatohead908 wrote:Nope. It only shows on the print.
I've seen this featured called "prime" something... It's inserting start g-code to print a prime line before the print starts. Unfortunately, the coordinates it chooses to do it are right in the way for you.
							*not actually a robot
				Potatohead908
Oddly enough it does this midway through the first layer printing. I have caught it and stopped it each time so I don't know if it would just continue on with the print.
				BenTheRighteous
What slicer was giving you the problem?
That's REALLY weird then... it looks very intentional haha. Is it some kind of tool chance gcode that is mistakenly being inserted?
				Potatohead908
I think it may have started in Matterslice however I changed to Slic3r within MC about the time it started. I can't remember which one it started in but it does it in both Matterslice and Slic3r within MC.BenTheRighteous wrote:What slicer was giving you the problem?
					Last edited by Potatohead908 on Mon Aug 17, 2015 1:00 pm, edited 2 times in total.
				Potatohead908
I don't know. Moving to an external copy of Slic3r and printing from and SD card has eliminated the issue.Eaglezsoar wrote:If I understand this correctly, your old slicer is what was causing the problem?Potatohead908 wrote:Nope. It only shows on the print.
Great that you got it to work.
