Why am I getting this line thru my print? It just started happening.
If I understand this correctly, your old slicer is what was causing the problem?Potatohead908 wrote:Nope. It only shows on the print.
I downloaded Slic3r and just print via SD card. Same STL's and no false line.
I think it may have started in Matterslice however I changed to Slic3r within MC about the time it started. I can't remember which one it started in but it does it in both Matterslice and Slic3r within MC.BenTheRighteous wrote:What slicer was giving you the problem?
I don't know. Moving to an external copy of Slic3r and printing from and SD card has eliminated the issue.Eaglezsoar wrote:If I understand this correctly, your old slicer is what was causing the problem?Potatohead908 wrote:Nope. It only shows on the print.
