Max Metal Aluminum Bed Mount Including FSR Mounts
This is what I came up with for mounting my bed to the Trick Laser Max Metal frame based on geometry provided by Brian. It includes pockets for FSR's. I'm making it out of aluminum, but if you're creative and cut it up, I'm sure it could be printed then glued.
- ZAKS BED MOUNT INCLUCING FSR POCKETS.STL
- (84.46 KiB) Downloaded 313 times
- ZAKS BED MOUNT INCLUCING FSR POCKETS.DXF
- (58.82 KiB) Downloaded 295 times
- Renha
Re: Max Metal Aluminum Bed Mount Including FSR Mounts
Thanks! i'll check it later
EDIT: strange dimensions in STL
3D printing is magic!
Sorry, it is in inches. If I can fix anything, please let me know.Renha wrote:Thanks! i'll check it later
- bvandiepenbos
Netfabb can scale inch parts to MMRenha wrote:Thanks! i'll check it later
(simply scales it up 25.4)
probably could do the same in Repetier, Matter Control or whatever slicer you use.
although I think netfabb does a better job re-sizing.
I *ALWAYS* run my parts through netfabb before slicing, to fix any issues and to verify size.
