glueing PLA to ABS
				10kvclockman
- Plasticator
glueing PLA to ABS
Hi, I have created some PLA gears and have just printed some ABS hubs.  What bonding can I use to join them.  I have attached the stl of the two components but they are made of two different plastics, any ideas?
				- Centre orrery gear with hub.stl
- this is the complete assembly
- (5.22 MiB) Downloaded 243 times
Re: glueing PLA to ABS
I've used good old 5 minute epoxy to great success. Rough up the surfaces a bit first.
							Orion to Cartesian     http://forum.seemecnc.com/viewtopic.php?f=59&t=7808" onclick="window.open(this.href);return false;
				10kvclockman
- Plasticator
Thanks I will give it a go, might try reprinting the gear with a hub as part of the assembly
