Kisslicer and the skirt
- foshon
Is it possible to get a continuous skirt like in Slic3r? I use a 5mm skirt on long/large prints, but have to use Slic3r to get it. I really don't care for the raft, with no perimeters it seems to curl as quickly as the print I am trying to help. Slic3r seems to implement it as an "enlarging" of the first layer by 5mm which works out perfectly for me.
							Purple = sarcasm
Re: Kisslicer and the skirt
I think it's called "brim" and already in the Kisslicer wishlists: http://kisslicer.com/forum/index.php?topic=361.30 http://kisslicer.com/forum/index.php?topic=163.0
						- foshon
Thank you. Do you know if it is in the current beta? I have tried several times to register on their forum, I never get the activation email.
							Purple = sarcasm
I don't think so. Which version do you need?
						- foshon
I'd like to play with the new beta. I can't find his github.
							Purple = sarcasm
You wrote already, that you need the beta. But for which sysem? Mac, Windows, 32Bit, 64Bit, ... ?
KISSlicer is not open source so no github. You can find the 1.1.0 release candidate (no longer beta) in the forum: http://kisslicer.com/forum/index.php?board=6.0
- foshon
Windoze xp
Without a login to the forum pictures and links don't work. This is the root of my issue.
Purple = sarcasm
- foshon
I actually am a "pro" user. LOLmhackney wrote:KISSlicer is not open source so no github. You can find the 1.1.0 release candidate (no longer beta) in the forum: http://kisslicer.com/forum/index.php?board=6.0
Purple = sarcasm
I don't know what this means or what you want to say.foshon wrote:I actually am a "pro" user. LOL
Again: Do you need 32 or 64 Bit?
- foshon
I'm sorry, missed that 32 bit. That was meant for Mr. Hackney.
							Purple = sarcasm
Here you go
				- KISSlicer_Win32_1_1_0_RC1a.zip
- (564.51 KiB) Downloaded 419 times
- foshon
aehM_Key wrote:Here you go
Thank you sir!
Purple = sarcasm
All of the RC2s are here: http://kisslicer.com/forum/index.php?topic=489.0
I am trying it out now. It has some new features too (italics):
EDIT 2013-03-25: updating to RC2
* Seam can now be randomized (Jitter) and the depth of the seam crossover can be modified.
* Fixed some tab-order issues
* Fixed some translation / menu / tooltip string update issues
* Added a delta speed limit (1st layer speed limit is increased by this each layer, so you can do gradual speed increases)
* Fixed a huge crowning bug! The speeds and widths should be sane now.
* G-code comments now wrap to stay within 62 characters
* removed some double quotes that were choking the translator
The seam randomizer is great! I missed that from Slic3r.
do you find that the seam randomizer give you inconsistent and jagged edges?
				Bill Havins
Yes.ichiban wrote:do you find that the seam randomizer give you inconsistent and jagged edges?
"So many windmills, so little time."  - Don Quixote
