[img]http://i.imgur.com/S51ar0Dl.jpg[/img]
[img]http://i.imgur.com/AP19yaul.jpg[/img]
As you can see from the photos, the top layer on these calibration cubes is not printing properly.
Layer Height: 0.1mm
Heatbed: 90C
Extruder: 223C
Filament: ABS
Slicer: MatterControl
All hardware is that of the stock machine.
The common cause of this is too few solid layers, but I have successfully printed at 0.2-0.3mm layer height with 0.8mm of solid top layers. I've experimented with speeds as well. The cube in the second image has an infill speed of 50mm/sec. Various amounts of infill have also been tested and though it may prevent holes in some cases, warping still occurs. I ended up printing over a dozen of these calibration boxes, changing one setting at a time, to no avail
Thanks,
Matt
