Using Tetrahydrofuran to clean nozzles used with PLA?
milp
Post by milp »
Hi,
I read that Tetrahydrofuran dissolves PLA like aceton does with ABS. I ordered a bottle and dropped two old and presumably "dirty" nozzles i used mostly with PLA filament into a glass with some THF for two days now. They look a little cleaner now, but it still seems there is some residue inside them. Has anyone else tried this?
Anyone know what type of rubber gloves i could use to protect myself from THF? Nitrile golves dissolve.
KAS
Re: Using Tetrahydrofuran to clean nozzles used with PLA?
Post by KAS »
Seems like we've been down this road recently. Maybe that was just MEK?
MSDS: http://www.pennakem.com/msds/109-99-9_T ... K_msds.pdf
Look under PPE for the hand section, will list the type of gloves required.
milp
Post by milp »
MEK? Is that some other kind of solvent?
bot
Post by bot »
Methyl Ethyl Ketone. It's SOME kind of solvent. One of the most solventy of the solvents I've ever seen. Don't mess with it carelessly.
*not actually a robot
milp
Post by milp »
Oh nice, so that could be used as a good nozzle cleaning tool then, is it effective?
What gloves can you use with it? PVA? Can nitrile be used as short term protection for handling?
KAS
Post by KAS »
This should cover your glove fetish.
http://www.ansellpro.com/download/Ansel ... eGuide.pdf
Or the interactive version: http://www.ansellpro.com/specware/guide.asp
milp
Post by milp »
KAS wrote:This should cover your glove fetish.
Awesome thanks! Now i can get really kinky with all the solvents. :D
Any experiences with MEK as a nozzle cleaning agent?
