It has been a while since I posted here.
I have been having some issues with my Maxx v1 lately and I was hoping that some of you have seen this issue before.
This past week I have been trying to get my Maxx back up and running. I replaced the Glass Bed (old one de-laminated) and the nozzle (which I thought was clogged). I spent a good deal of time trying to relevel everything. So today I finally got the bed leveled, the horizontal radius set, so I was getting ready to do my first print in a long time. I heated up the Extruder & Bed for ABS, Put in some fresh filament. And started to prime the hotend.
I did my normal procedure, in that I manually feed the filament to the PTC fitting and then use Mattercontrol to slowly feed the hotend. This time everything STOPPED. by stopped, I mean the extruder would not feed, or retract, the filament. The temperatures stopped updating. And would not shut down the heaters either. It is almost like Mattercontrol and my Maxx disconnected, without reporting that the disconnect took place. So I hit disconnect on Mattercontrol and restarted my Maxx. I was able to retract the filament 2-3mm before it happened again.
I decided to try Cura, hoping it was a Mattercontrol issue. It happened in Cura also.
Here is my setup...
- Mattercontrol Version 1.3.0
 - Cura Version 15.02.1
 - Rostock Maxx V1 Firmware Version .91
 - Communication Type - USB Cable
Any wisdom you can share would be appreciated.
