276 mm
bot
276 mm
Post by bot »
teoman
Re: 276 mm
Post by teoman »
That is quite an accomplishment. Well done.
Re: 276 mm
As Teoman says Well Done indeed.
bot
Re: 276 mm
Post by bot »
Thanks guys! I'm pretty stoked about this printer now that I have it calibrated well.
*not actually a robot
KAS
Re: 276 mm
Post by KAS »
Absolutely impressed with your design and capability. Great job!
stonewater
Re: 276 mm
Post by stonewater »
could you post some pics of your machine and some of its features?
Tom C
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
bot
Re: 276 mm
Post by bot »
I will definitely do a good write-up and maybe some more videos soon. Check out my youtube channel for some videos: https://www.youtube.com/channel/UC5i9sh ... UVQBTPRyXw
The jist of it is that it's an all aluminum frame, with an expanded horizontal footprint. The print volume is designed to be the exact specs of the rostock max -- 280 mm cylinder by 14" tall. The actual maximum dimensions are about 276 mm and just over 350 mm in print height depending on where you print. Near the towers it's slightly less than 350.
It's designed for precision/accuracy/resolution and rigidity/stability. The arms are quite long and ringing artifacts are still present, so the print speeds are not much improved from a rostock max. I'm pretty picky when it comes to visual quality, so some may be able to run this as fast as 150 mm/s printing and not mind the quality difference.
