Help please, weird non-homing/reversed X carriage?
tylurker
Post by tylurker »
Not exactly sure how to describe what my problem is, so I made a video. I was almost finished calibrating / adjusting endstops and HR after swapping to longer arms (~295.2 mm). The Z and Y macros were spot on and so was the X the first time I hit it, but after adjusting its endstop and hitting home to check the new height, the carriage started going the wrong way. I shut it off and reset the positions manually, and well you can see in the video.... (i had some trouble getting the embed to work so heres the url: https://youtu.be/K4zuTsili08 )
[youtube]https://youtu.be/K4zuTsili08[/youtube]
Im running Repetier 91s and everythings stock except the arms and hot end. HR is currently at 129.85 or so I originally started at 140 and have worked my way down. The prior iteration at 130.2 was almost good and everything went smoothly.
Any help is appreciated. Thanks !
Tyler
UPDATE... after re watching the video i realized my x tower endstop is probably stuck on and thats probably the whole problem..... agreed? again thanks!
KAS
Re: Help please, weird non-homing/reversed X carriage?
Post by KAS »
Pull your carriages down off the endstop switches and test with the M119 command. What does it show?
For youtube embedding, find the actual video url (https://www.youtube.com/watch?v=K4zuTsili08)
remove the s from https and place that url in the youtube brackets.
Like this
[youtube]http://www.youtube.com/watch?v=K4zuTsili08[/youtube]
tylurker
Post by tylurker »
m119 returned this:
<-ok 0
<-x_max:H y_max:L z_max:L
So new end stop
KAS
Post by KAS »
Just check to make sure it's wired the same as Y and Z. I believe using the two outside connections on the switch. Then make sure it's on the correct pins on the Rambo.
Post a picture of your Rambo, if anything doesn't stand out right away.
If that doesn't help, check that the wire are not crossing/touching the stepper wires. Although I would expect that to be a more intermittent issue.
Edit: I just noticed your forum registration date and realized this wasn't a new build. If it's been working, then it might be a dead switch. You can try to manually wiggle or push the button in, might work to reset it.
