WHAT WITCHCRAFT IS THIS?!
MUAHAHAHAHAHAHA!
Re: WHAT WITCHCRAFT IS THIS?!
What's this.. a new stock power supply?
I could tell you, but then I'd have to make you use a Makerbot.
If that's a 24V power supply stock, then I am very much want. Although I wish it weren't using a side panel for the plug, ETC, as I like clean lines, and also kinda planned to have a cable duct living on the two non-door sides.
The 12 volt supply works very well also. Alot better then a PC PSU. I cannibalized a powersupply for the back panel, for the power cord, and used the kits power switch to switch the mains.
Slots in the base are different from the v2.
Of course the images give away the instruction changes, specifically:
fig6.8-1 & fig18.4-5
You can print covers for the LED PSUs. Designed appropriately, you can integrate them however/wherever you want. My Mendel came with one, then I designed one for a 30A upgrade and then one for a 24V upgrade
