40 mm Stand Alone Fan for My Smoothieboard
draw-tech
Post by draw-tech »
Hi All
Setting up my test station to test the 300C hot end, using a Smoothieboard. i will be pushing the board using relays to power an all aluminum bed plate, It will have two zones controlled with two thermistors,
each zone I estimate will draw about 14 A and about 85 watts. I.m starting out a little overkill, then can cut back on the amount of heating resistors I will need. So I need a fan that I can move around to cool the board, or whatever.
Fan_Stand.zip
(1.63 MiB) Downloaded 285 times
barry99705
Re: 40 mm Stand Alone Fan for My Smoothieboard
Post by barry99705 »
That's a cool little fan stand!
barry99705 wrote:That's a cool little fan stand!
And it is a breeze to make!
