Will be receiving my Max2 soon and thought I'd start on an enclosure. Decided on 1/4" plywood approx. 1" larger than the V2, with 18" wide clear PC front door. I plan on using a 125W (or 250W) heat lamp bulb screwed to a porcelain base under the top assy of the V2. I'd like to keep the heat above room temperature 24/7 (or at least in the winter when my garage is below 60F). Will a water heater thermostat work at controling the temp within the enclosure? Something like this?
http://www.amazon.com/gp/product/B001AT ... 1_3&sr=8-3
The filament reel on top will be within the enclosure. Should I add a small fan to circulate air (in the top section so there is little to no breeze below). Will be printing ABS.
PS: Holy crap, UPS just dropped off "the box"... ordered on Thanksgiving! Wife says "oh no, won't be seeing you for a while".
Enclosure heating
Re: Enclosure heating
I think a digital temperature controller such as this one: http://www.amazon.com/Inkbird-All-Purpo ... controllertcat007 wrote:Will be receiving my Max2 soon and thought I'd start on an enclosure. Decided on 1/4" plywood approx. 1" larger than the V2, with 18" wide clear PC front door. I plan on using a 125W (or 250W) heat lamp bulb screwed to a porcelain base under the top assy of the V2. I'd like to keep the heat above room temperature 24/7 (or at least in the winter when my garage is below 60F). Will a water heater thermostat work at controling the temp within the enclosure? Something like this?
would better suit your needs.
Thanks, that looks more controllable, and you can see the temp. Sure are a lot of parts in the box! Anyone ever count them all? Doesn't look too intimidating.
Sure smells, even before opening. Must have been cut less than a week ago...
BenTheRighteous
I have the exact controller Eagle recommended. It works like a charm.
