max V1,
   I have a problem with it connecting using arduino or any slicing engine.  when I plug it into the usb, software recognizes it and you can see the comport. the lcd screen blinks and I get 1 beep.  arduino sees it when I start it up. sees the com port and the right board. when try to upload eeprom no luck. when I use the machine control in s3d it shows it trying to conntect all 3 ways and times out.  I have tried setting baud rate in software and changing it on the LCD. any ideas?  I cannot clear the EEPROM or anything like that.  I can run prints off the SD card and do any of the machine changes and save to EEPROM on the LCD screen.  mattercontrol starts to connect but cannot finish the connection.
  any ideas please? tried 250000 and 115000.   when you access the com port settings in device manager it shows 115000 as max speed... tried this with a win7 machine and an older xp pro machine. boh used to  work with the max, I suspect tit may be a problem with the card. I can connect to my robo and to my flashforge no problems. they use different com ports but its working.
Tom C
							Rambo connects.... sort of
				stonewater
Post by stonewater »
MAX V1
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
Corvair750
V6 Hotend
Robo 3D
Flashforge creator
				Jump to
	- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
