- hot end - for the, well, hot end
- cold end - the cold zone above the hot end
- filament driver - the stepper-driven device that pushes the filament
- extruder - the hot end, cold end and the filament driver
I've been looking for a filament driver that has enough muscle to reliably push filament through the maze-like hot end of the Cyclops. Each of the two filaments makes two 90° turns in the hot end on this extruder. While this does minimize oozing and color bleeding and results in a pretty short color change-over, it does make demands on the filament driver. Although I've modified all of my ezStruders with all the upgrades posted in this forum, including geared steppers, continuously supported filament path, etc, they occasionally hiccup with the Cyclops. They handle every hot end I've thrown at them but Cyclops is unique.
I researched a lot of options but of course it is very difficult to determine if a device will actually work for your application. After lots of discussions with vendors and other users I decided to give the new Bondtech QR filament drivers a try. These devices have two cogged gears that are both driven by the stepper. This is similar to the way SeeMeCNC's original Steves Extruder worked. It is a really compact little unit and the filament is completely supported on both sides of the gears. Pricy but if they work as well as claimed they will be worth the expense. I'm dangerously close to being able to print fly reels in two colors or some special designs and just need a little more reliability. Of course I post back once I've worked with them for awhile.
The developer, Martin, actually created a "kit" for me that does not include the geared steppers so I can reuse mine. Saves a little money also. The business end is pre-assembled.
My short list included the Bondtech QR, the Bulldog XL and the Micron 3DP Cobra or "all-metal" filament driver.
