When I use the Arduino ide software to upload it says It's done but it doesn't reset to a working screen like the instructions say....
Bill
PCB beds are never flat and if they are when cold they still wouldn't be when they heat up, it's one of the reasons you put glass or some other known flat substance on top.bplemmons wrote:Are you still building yours? Have you noticed if you onyx in warped? mine is. try laying a straight edge over it. mine is off by about 5/32. Even though I have a glass plate on order, I'm concerned that i wont get good heat transfer.....
Bill
and it worked, now i'm using repetier FWin arduino IDE when you open any file from the project for example configuration.h all the files will be loaded. And i don't know if this make a difference if you open your marlin project by marlin.pde or another file, but for me it's working when I opened it by marlin.pde. And one thing more: when I downloaded Marlin-for-rostockmax-ramboLCD it won't work for me. I have to download Marlin-for-rostockmax-rambo and copy/paste all the setting from the Geneb manual, and everything is now working
do you have a copy of your working marlin firmware with lcd? I was working from the rambolcd wiki page and marlin master file.gabrielk wrote:had the same problem with lcd on Marlin FW, but i do something like this using arduino 022 and changing pin file (exactly 022, not newer IDE)and it worked, now i'm using repetier FWin arduino IDE when you open any file from the project for example configuration.h all the files will be loaded. And i don't know if this make a difference if you open your marlin project by marlin.pde or another file, but for me it's working when I opened it by marlin.pde. And one thing more: when I downloaded Marlin-for-rostockmax-ramboLCD it won't work for me. I have to download Marlin-for-rostockmax-rambo and copy/paste all the setting from the Geneb manual, and everything is now working
Yours does exactly what mine does if I use John's Marlin file. Try the repetier firmware to see if it works. Something is wrong with John's LCD Marlin.jesse wrote:I have a similar problem and will probably be sending it back to get tested.
[img]http://i.imgur.com/SSpo6sp.jpg[/img]
I ordered a replacement LCD on eBay ($8).
http://www.ebay.com/sch/LCDs-Displays-/ ... 0x4&_frs=1
