My only quibble is that the screen capped MatterControl images are different than the current version of MatterControl. Apparently the GUI changed a little? No biggie really because I was able to figure it out.
Good manual. Thanks.
This is very unusual. I've never heard of them doing this.VAXHeadroom wrote:A few assembly notes, some related to the manual, some to the parts themselves.
- Page 9 (and sections 21 and 22): the fan shrouds were included in my kit, so a roll of ABS plastic was not required to make them.
Not necessary at all.[*]Page 28 HIGHLY recommend adding thermal paste in between the hot block and the nozzle. The thermal transfer across threaded surfaces is really not very good, and really the only part we actually WANT hot is the very top of the nozzle where the plastic touches it! If added, this needs to be added to optional parts list, Page 10.
In this case, the RTV is more of an easily removable, high temperature adhesive. The hot end is made from aluminum because aluminum sheds heat better than brass does. The nozzle needs to have some thermal mass to it, whereas the heater block does not.[*]Page 29 Just a thought on the RTV - this stuff isn't really designed to transfer heat, but apparently it works well enough. But the thermal transfer from the resistors to the nozzle is so highly critical in these applications it really makes me wonder why the hot ends are aluminum? Brass transfers heat 3x better than aluminum - why aren't the hot blocks made of brass? Similarly, stainless transfers heat even more poorly then aluminum - is the tube between the hot block and the PEEK section aluminum or stainless? I realize this is really a question about hot-end engineering, not the manual, but this is where I came to this in the manual![]()
The nylon spacers are the correct thickness. I've been teaching a group of high and middle school teachers how to build the Rostock MAX this week - they're all using the same spacers you are.[*]Page 75,76 The plastic washers used as separators between the mounting plate and top plate of the base were too thick - I had to substitute 2 metal washers at each location. I don't *THINK* I used the wrong screws as I wasn't short any others but maybe?
The 18ga wire HAS a drain wire, but is missing the nylon cord. The nylon cord is used to strip the jacket as the drain wire isn't strong enough for the task. (I suspect their source for the 18ga wire changed vendors and the vendor doesn't include the nylon cord.)[*]Page 79 the 18ga 4 conductor wire did not have a drain wire in it, making it difficult to strip the outer insulation. It had nylon instead which could not be used as a stripper. The 22ga wire did.
This has been fixed in the 3rd Edition, which should be out of QC soon.[*]Page 91 As others have said, the orientation of the base plate for the top section is easy to get upside down, and takes about a half hour to disassemble and flip.The part should really have TOP cut into it somewhere...
That's the first time anyone has mentioned to me that this has happened. Curious.[*]Page 133,138,140 In my filament guide block, the metal cylinder was installed upside down. I didn't realize this until I went to attach the push fit connector (Page 140). It was easy to fix, but you should add a check to page 138 to check before installing.
Not my call. I'm only the docu-monkey.[*]Page 146 (only because this is the first place wires are soldered), heat shrink is REALLY the way to go. I recommend adding a heat shrink kit it to the optional parts list, Page 10.
If they all worked backwards, you didn't install them according to the instructions.[*]Page 194,229 I got the stepper motors that had connectors without keys. I plugged them into the RAMBO with wires in the shown orientation - and they all worked backwards. The easiest way to fix that is just turn the connectors around. There really should be some check for this prior to calibration!!
User choice.[*]Page 198 the mounting orientation of the on/off switch is not specified. Since on and off aren't marked on the switch, I guessed, and then had to re-mount it. I mean, UP really needs to be ON right?!?![]()
Possibly.[*]Page 205 the acrylic cover for the X axis didn't fit between the on/off switch and the front cover plate and I had to nip a corner off the acrylic to make it fit. Was this because of the orientation of my on/off switch?
Yes, REALLY. If you think that's bad, you're gonna hate the NEW process. You do that one by eye.[*]Page 236 Paper? REALLY??? PLEASE strongly recommend 0.1mm feeler gauge instead. If you take this suggestion, a feeler gauge set needs to be added to Page 10.
The glue works perfectly. Everyone has their own pet way of doing things. The glue stick is the most newbie friendly method available and it works well.[*]Page 249 IMHO the purple glue is a HORRIBLE idea. Kapton tape and Acetone/ABS slurry works perfectly for both ABS and PLA and gives flat smooth prints on the bottom surfaces. I could not get parts to reliably stick with the glue. If you were to recommend it, Acetone and 2" to 6" Kapton needs to be added to the options parts list on Page 10. <-- STRONGLY RECOMMENDED (maybe not so humble opinion?)
Not a bad idea. I was discussing that one with one of my students yesterday. The only problem is that it has the potential to add a single-use expense to the kit cost. Not everyone that's got a 3D printer may need a meter laying around. [Now you and I know that _everyone_ should have at least two meters, but we're nerds and don't count.[*]General: Wiring is never checked for continuity? Recommend adding a multimeter to the optional parts list (Page 10) and adding resistance checks for the wires as you assemble them - especially stuff that has to be soldered. WAY easier/faster to check and fix before buttoning things up!! I didn't have any issues with this actually, but as an engineer it came to mindIt would also let you know unusual stuff like the fact that the end stop switches are normally open, not normally closed
I'll be the last one to argue this point, but remember, I'm just the monkey that writes the manuals.[*]Parts rant: I *REALLY* wish all the screws were metric cap head screws! IMHO everything on these printers should be METRIC and assembled with METRIC hex keys, not phillips head screws! /rant[/list]
I'm glad you liked it! The 3rd Ed. has blown up to 328 pages. I'm hoping they'll get the review done soon.These are all minor nits. The manual is REALLY good. I built my Max V2 in 18.5 hours. I videoed the whole thing w 2 cameras in HD. I'm a few hours into the video editing, don't expect it soon, but I'll post it here when I get it up on YouTube. I'm getting GORGEOUS prints in both PLA and ABS. I have a Makerbot Thing-o-Matic at home and a Leapfrog Creatr at work - this one blows the Creatr out of the water. I've had LOTS of problems with the Creatr - NONE with this so farI have 3 years experience with the Makerbot (which still works great), so I got into 3D printing pretty early and have lots of experience. I really look forward to helping on forums here!
Red for positive, black for negative.cookiemonster wrote:Hay guys,
Just a quick question regarding page 203 and checpoint video #20.
Even though I have the fan case oriented correctly, the fan blades seem to be reversed.
Does this mean I need to flip the wires?
Time Travel?mhackney wrote:Version 18.3 dated April 1st, 2019 for the Rostock V6.
Damn, I just figured it out, damned time travel messed up the PDF.
