Another rostock max build
Re: Another rostock max build
If you locate that kapton or silicon heater that you are looking for please let us know, there is a lot of complaints with the Onyx not being flat.
I have a silicone heater that I am working to test. The issue with these is they are not flat - there is a bulge where the wires and electronics are embedded. A special plate needs to be constructed to use these. Unfortunately, I sold all my plates so I need to wait for the next batch (should be today or tomorrow).
cambo3D - I just posted on another thread about the Al plate. I tested the deflection in a 40ton hydraulic press and it took A LOT of pressure to cause a measurable deflection of .1mm. There is something very odd going on here. My machine was very well cut and went together without these issues.
cambo3d
Post by cambo3d »
I took the time to do some current draw testing for the onyx today. Here are the results.
I have not tested the stock 12v supply, because it's not wired for the onyx in my build.
Initial current draw for each temperature is from room temp.
cambo3d
Post by cambo3d »
with the thin walled calibration print, what exactly am i checking for? height, width,??? http://www.thingiverse.com/thing:5573
or just thickness of the wall?
At this point:
getting good first layer adhesion - check
getting good layer adhesion without gaps or overfill - check with a little work to do on the blobs. Your extruder appears to be reasonably well calibrated and filament pressure correct.
no signs of backlash (i.e. parallel sides, plumb sides, layers stacked properly) - check
Now you can measure wall thickness, width and height and compare to your model and slicer settings - priceless (sorry, had to add that!)
cambo3d
Post by cambo3d »
mhackney wrote:At this point:
do i really need to check that last line, or was that just being funny? seriously i dont know...lol
foshon
Post by foshon »
cambo3d wrote:with the thin walled calibration print, what exactly am i checking for? height, width,??? http://www.thingiverse.com/thing:5573
I have used that to help calibrate x-y steps/mm by comparing the width and length to what it was supposed to be. Most often though the goal with that cube is to tweak single wall thickness. Try to get a good measurement of the wall thickness, one layer is best (be careful not to cut into it with calipers). Now compare that to what the g-code thought the layer thickness was. If they are close, tweak your extruder flow modifier in the slicer. If they are way off apply the change to your e-steps/mm.
http://reprap.org/wiki/Triffid_Hunter%2 ... tion_Guide
Shoot down to "Slic3r/Skeinforge/Sfact settings".
Hope it helps.
Purple = sarcasm
Sorry, I was being serious and funny all at once! It is good to verify dimensions at this point.
cambo3d
Post by cambo3d »
Hope it helps.
can't get that link to work..edit: finally popped up
cambo3d
Post by cambo3d »
i'm noticing my extruder is getting loud, sounds like wood creaking ...hmmm
Egads foshon, that avatar scared the he!! out of me!
Av8r RC
Post by Av8r RC »
Mine also creaks. And sounds like a can full of rocks on retracts. My other printer has a direct drive extruder (bowden also) and is much, much quieter. I want to figure out how to get one on here and try it out.
cambo3d
Post by cambo3d »
I tried to post a youtube video but its scrambling the video for some reason.. grrr.
Mine has the same squeak. I haven't gotten a chance to try 3in1 Oil on the gears yet.
cambo3d
Post by cambo3d »
I took the extruder apart and checked it nothing seems to be out of the ordinary, but at the same time while it was off, i sanded a bevel into the smaller gears near the filament roller, it seemed like it was rubbing against the bottom of the bowden adapter nut. I Put it all back together and the creaking noises went away. I can't be positive that's what caused it but might have been a combination of that and retorquing the assembly bolts. at least the noise is gone for now.
ApacheXMD
Post by ApacheXMD »
gabrielk had that issue too and he posted about shaving a bit of plastic to allow the knurled nut to thread a little higher up to avoid the gear
http://forum.seemecnc.com/viewtopic.php?f=35&t=1168
cambo3d
Post by cambo3d »
ApacheXMD wrote:gabrielk had that issue too and he posted about shaving a bit of plastic to allow the knurled nut to thread a little higher up to avoid the gear
I saw that but i didn't want to sand that area down, i think its that length for a reason to help the filament from binding. I think beveling the gear is a better idea
cambo3d
Post by cambo3d »
I got a little ambitious last night. Since my calibration prints were coming out ok, I'd try something more useful. The spool holder, not perfect but still gonna be put to use. http://www.thingiverse.com/thing:60750
what infill pattern would you have used for the base of the spool holder and how do i get rid of the blobs.
The print looks pretty good.
On the base it just looks like you are extruding too much plastic.
cambo3d
Post by cambo3d »
Polygonhell wrote:The print looks pretty good.
do i just adjust flow rate, while its printing to reduce plastic? then change it back when the infill is done?
This is what I do to calibrate, print a single wall print adjust flow rate then verify with a 100% fill print.
http://forum.seemecnc.com/viewtopic.php ... 5452#p5452
cambo3d
Post by cambo3d »
thanks!
Make sure you only use that for its intended purposes.
cambo3d
Post by cambo3d »
Since i broke my lcd angle mount trying to take my defective seemecnc lcd off. I had to figure out an alternative way to mount it and still have access to the sd card slot.
here is my solution. Its not angled like I wanted but it works. SEEMECNC CAN I GET A REPLACEMENT ANGLE MOUNT, WITH MY REPLACEMENT LCD???
cambo3d and others, I HIGHLY recommend that you contact SeeMeCNC support directly and not make requests in posts. They do not monitor this forum on a daily basis. Simply check the member list and sort by last visit time and you will see what I mean. Even if they did visit everyday, the volume of posts would make it difficult for them to find requests like this. Email customer support!
Cheers,
Return to “The Build Zone”
