error uploading repetier
- Plasticator
i am trying to upload the repetier firmware and it keeps giving me the same error im new to coding so i was looking for Little help or guidance if it is the a hardware issue or if it is a firmware issue i have a rostock max v2 here is the error message that i keep getting if any one wants i can copy whe whole thing in here if it might make it easier to solve
C:\Users\jgardner\AppData\Local\Temp\build42879d3f4a51ad5a156a0c9e9b8b6401.tmp\sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
#include <twi.c>
compilation terminated.
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
exit status 1
Error compiling.
thank you
#include <twi.c>
exit status 1
Error compiling.
thank you
Re: error uploading repetier
I'm guessing that the version of Repetier firmware that you are trying to load was written for a different version of the Arduino IDE. The library inclusion is failing because the compiler can't find it. It should be possible to alter the Repetier sketch, but far simpler to just download the matching version of Arduino IDE.
- Plasticator
Earthbound wrote:I'm guessing that the version of Repetier firmware that you are trying to load was written for a different version of the Arduino IDE. The library inclusion is failing because the compiler can't find it. It should be possible to alter the Repetier sketch, but far simpler to just download the matching version of Arduino IDE.
from what i know i used everything that seemecnc.com has said to in there instructions i have a rostock max v2 with an arduino/genuino mega or mega2560 trying to upload repetier .091 firmware it looks like everything matches. heres the link from where i got it ( http://www.seemecnc.com/pages/downloads )if you download it and look through the folder and open the libaries folder in that there is a file that is twi.c but it looks like it is the only file in that is .c everything else looks like it is .cpp but i dont know what that mean
thank you
jeremy
What version of the Arduino IDE are you running? That is NOT specified on the SeeMeCNC page. The Repetier release on the page is a few years old. It is very possible that you are using the most recent Arduino IDE and it is not compatible. Look at the About dialog in the IDE to get the version #.
- Plasticator
if im looking at the right info i beleive it is a rambo 1.31L i got that info from the wiring diagram that came with the setmhackney wrote:What version of the Arduino IDE are you running? That is NOT specified on the SeeMeCNC page. The Repetier release on the page is a few years old. It is very possible that you are using the most recent Arduino IDE and it is not compatible. Look at the About dialog in the IDE to get the version #.
It's not a hardware problem, as it's failing before it gets to the upload part, during compiling. Compiling is the step where the human-readable code is turned into machine code.
When you start up the Arduino editor, what is the version number on the top bar? If it's not at least 1.6, you should go get a more current version.
jerome, no that is not it. Arduino is the programming environment that compiles the firmware and uploads it to the machine. You get it here: https://www.arduino.cc
You have installed it haven't you?
- Plasticator
Ok, did you configure Arduino for the correct board under Tools-> Boards menu?
- Plasticator
yea its arduino/genuino mega or mega2560 and it is on com5 the eeprom seem to work fine when it had me run that
- Plasticator
im not sure if this helps but heres the complete error
Arduino: 1.6.7 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\jgardner\Documents\Arduino\libraries" -fqbn=arduino:avr
cpu=atmega2560 -ide-version=10607 -build-path "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp" -warnings=all -prefs=build.warn_data_percentage=75 -verbose "C:\Users\jgardner\Desktop\Repetier-091-ROSTOCKMAX-master (2)\Repetier-091-ROSTOCKMAX-master\Repetier-091-ROSTOCKMAX\Repetier\Repetier.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\jgardner\Documents\Arduino\libraries" -fqbn=arduino:avr
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Repetier.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Repetier.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\SPI.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Commands.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Communication.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Eeprom.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Extruder.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\HAL.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Printer.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\SDCard.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\SdFat.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\CDC.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\HardwareSerial.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\IPAddress.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\Print.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\Stream.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\Tone.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\USBCore.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\Repetier.ino.cpp" -o "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WInterrupts.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WMath.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WString.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\main.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\new.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_analog.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_digital.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_pulse.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_shift.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\gcode.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\EEPROM.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Ethernet.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Firmata.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\LiquidCrystal.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\OBD.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\SD.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\SPI.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Servo.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\SoftwareSerial.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Stepper.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\TinyGPS.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\U8gui.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\WiFi.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\Wire.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\motion.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\ui.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino5/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\WInterrupts.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_analog.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_digital.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_pulse.c.o
Using previously compiled file: C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\cores\wiring_shift.c.o
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\mega" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI" "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c" -o "C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c.o"
C:\Users\jgardner\AppData\Local\Temp\build03da911c33663a65c85edf1a0eeee7f3.tmp\sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
#include <twi.c>
exit status 1
Error compiling.
#include <twi.c>
exit status 1
Error compiling.
It really seems environmental. The basics: do you have enough free disk space? Have you successfully compiled one of the simple demo apps that comes with Arduino IDE under File->Examples? Pick a few and see if they compile.
- Plasticator
smart thinking
so i tried a couple and they all compiled
if it says compiled complete is that a pretty good idea that the board is working
it seems like my only issue is the repetier firmware and that twi.c
any other ideas i emailed seemecncs support so im curious what they will say i was just really hoping to get this going so i can start calibrating it
jeremy
jeremy
That's good. That shows arduino ide is setup. How about going to repetier and downloading the firmware. Don't worry about configuring it we just want to see it compile. Would be a good test while you wait.
- Plasticator
might be a dumb question but where do i download it i tried one thins but it seemed more like a slicing program instead of the firmware
- Plasticator
ok so i did that but i wasnt sure how that get to the board and do you know if both the green light and the orange light should always be on
DO NOT upload it. Just test if it compiles.
- Plasticator
gotcha yea no luck on compiling
- Plasticator
i dont know why but im so lost with this at the moment
This step is trivial usually. Something is fishy.
Try on a different computer. Download arduino and the repetier firmware and see if it compiles (check mark on the arduino window). (The right arrow compiles and uploads it).
I just did a Skype session. I had him install Arduino 1.6.0 and a fresh copy of the firmware from SeeMe. Same problem. He mentioned this is a work laptop so "ding" - maybe there is some antivirus or lockdown on it. It has to be environmental as I installed the same versions of this stuff and it compiled fine. He's digging out another PC to try.
Good job Michael and thanks to going to such extents to help a fellow Forum member. You DA MAN!mhackney wrote:I just did a Skype session. I had him install Arduino 1.6.0 and a fresh copy of the firmware from SeeMe. Same problem. He mentioned this is a work laptop so "ding" - maybe there is some antivirus or lockdown on it. It has to be environmental as I installed the same versions of this stuff and it compiled fine. He's digging out another PC to try.
- Plasticator
after that talk with Michael and switched a couple things im ready to go i really appreciate all the help and im sure ill be back for more questions
Great! Was there something specific you found or was it the work laptop probably having virus checking?
