[quote="geneb"
]If there's no display on the LCD, you've got one or both cables flipped.
You could also have the interface board that those two cables plugged into, off by one or more pins.
g.[/quote]
You had it spot on Gene, I took a few min from  cooking today to check and that is exactly what I did....
I guess was in a hurry to finish my christmasy gift to myself before the day I missed the fact that
 Fig. 17.10-3: "A" & “B” cables installed.
 had flipped orientation from
17.10-1: Adapter labeled.
 on page 139 all due to my not following your fine words and music.... a very embarrassing face palm moment
 I had A to A and B to B but pin 1 was at the wrong end of each plugged into the daughter board
So when I sober up from the christmasy feast of roast beast tomorrow on Boxing day I will commence to calibrate ( if my reversal did not fry the LCD of course) then the 2 ABS fan shrouds and then over to PLA to learn the basics
Strong Christmas thanks to you all on the Forum  eep yourself and MHackney and Eaglesoar
I am following your youtube  build of the vintage 1984 Heathkit zenith PC with great interest as you are the writer of  the best high tech build manuals of the present day what do you think of your predecessors at Heathkit? I loved the way all the envelopes were marked with part numbers and in some cases contents  AS you can see from my first post in this thread I am using a heath kit soldering station from about 1969 that its what passed for temperature control back then.... just before I built it, I built an EICO DC tube type oscilloscope  and EICO manuals were a real trial by comparison...then in about 1972 or so a 25" color tV after the group that owned Zenith also bought heath kit it had about 25 seprate circuit boards and took about a week to calibrate... you had to make your own degaussing coil I recall but it was still working fine when we sold the house where it was built in in 1986... My last heathkit was a high end digital Multimeter that was patterned after a shulmberger instrument in the early 80s and it still gives good service
now that you have worked with that 1984 heath kit for a while I would love to hear your thoughts on their manuals
Thanks again so much for all of your help and I hope Santa was as good to you as he was to me (I got a E3D v6 kit and a Build-Tec disc with trick laser AL heat spreader) for when I graduate from PLA and the stock hot end in a while after I get a handle on the basics
