weird warping
DarthBeavis
weird warping
Post by DarthBeavis »
Can't figure out what is causing this warping. The piece on the right is warped the one on the left is how it should look. Any ideas?
[img]http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg[/img]
Using custom Rostock and Simplify3d
Re: weird warping
Image didn't post correctly.
Re: weird warping
Post by Xenocrates »
http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg Is the image. I think it's an odd bit of layer shifting, but it's hard to tell. Have you changed much between the two parts?
Re: weird warping
Xenocrates, I can't get your image to open either.
DarthBeavis
Re: weird warping
Xenocrates wrote:http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg Is the image. I think it's an odd bit of layer shifting, but it's hard to tell. Have you changed much between the two parts?
two different printers
Tincho85
Re: weird warping
Post by Tincho85 »
I can't see the image either.
Martín S.
Re: weird warping
That's really interesting. Are you using the same G code for them both? Would it be possible to use the same G code (is the nozzle size and so on close enough for that to work)? Do you see this on any other parts?
It looks like it might be resonance in the drive system or a slicing bug almost, since it's so regular. Have you checked the mechanics and if your hotend holder is loose?
magicmushroom666
Re: weird warping
Post by magicmushroom666 »
Did the code come from Slic3r? There's a bug in the latest version that causes thin walls to bulge like that...
https://github.com/alexrj/Slic3r/issues/2960
