Hello all,
So I am doing the command for the PID Autotune (M303 S200) and I got the "Temp too high" error (On my Orangesicle Printer), so I toned the Extr.1 PID Drive Max to 128 like the guide said to do, I re-entered the code and I got the "Temp too high" error AGAIN! After shutting the printer down, turning it back on, disconnecting MatterControl and doing all I could, the problem is not fixed. If anyone could help me that would be fabulous!
Any help greatly appreciated!
PID Autotune Temp Too High (Rostock MAX v2) (SOLVED)
-Aureus
My Printers:
Orangesicle (Rostock MAX v2)
My Printers:
Re: PID Autorun Temp Too High (Rostock MAX v2)
What is the maximum temperature you have set for your extruder? should be an EEPROM entry for that. What temperature does it reach while auto-tuning?
If it's drastically overshooting, try tuning to the temperature you want, minus the overshoot, and then after that adjustment is made, tune to your desired temperature. Or decrease P/increase D before tuning.
SOLVED
So, what I did to solve was as follows: I went to the EEPROM Configuration and edited the Extr.1 PID Max Value and I put that to 128, then I ran the PID Autotune and it worked!! After the PID Autotune worked, I went back to the EEPROM and changed the Extr.1 PID Max Value to 238. Hope this works for anyone who has this problem!!
-Aureus
My Printers:
My Printers:
