Rostock base panel for 92mm fan
- thedoble
I wanted to get a bit more airflow happening inside my rostock's base. I found my steppers get quite warm.
I'm also learning a new design package - Autodesk Fusion 360. Coming from Sketchup, it's a beast! I figured this would be a nice, simple design so I can start to learn how to model in Fusion.
Anyway here's the finished design, am printing it now. Hopefully I got my measurements for the holes right!
[img]http://i.imgur.com/0c0bzai.png[/img]
Smoke me a kipper, I'll be back for breakfast.
- thedoble
Re: Rostock base panel for 80mm fan
I got this idea from another design on thingiverse - added a 45 degree duct.
This should direct the air onto the X/Y steppers and past the electronics. I made the plate able to be installed upside down so you can have one on each side of the base and get PUSH>PULL airflow throughout.
[img]http://i.imgur.com/FzJf1yF.jpg[/img]
- Windshadow
Looks good but you might want to make a provision for an intake filter if you are sucking air in with the fan when I used to build my own PCs I found that cut up chunks of Airconditiong filters over all the places that air was being sucked into a case helped a lot with longevity and then I realize that if I changed the air flow of the the case fans so that they sucked in the air rather than blew it out I just needed to filter the fan intakes
I have been thinking about the Peek fan and wondering if I should do something to keep dust etc from the cooling ridges of the PEEK
- thedoble
Good idea, especially considering there's likely to be bits of filament floating around near the printer base.Windshadow wrote:Looks good but you might want to make a provision for an intake filter if you are sucking air in with the fan
You could simply put a bit of gauze or mesh over the front of the intake. I'll see if I can come up with a way to do it.
I finalized the design tonight - I didn't want to bother with finding the right length screws for the fan, so I made some little pegs - the fan clips on quite nicely and is held very snug.
[img]http://i.imgur.com/bN2RVHL.png[/img]
What did you use to generate this image?thedoble wrote:[img]http://i.imgur.com/bN2RVHL.png[/img]
- thedoble
It's auto-generated by repetier-serverjesse wrote: What did you use to generate this image?
You can take a look if you like - it's printing now.
http://3dprinting.thedoble.com
There's a webcam too
You play Eve Online, Don't you?
- thedoble
I used toXenocrates wrote:You play Eve Online, Don't you?
Nice work! I have also been using fusion 360 quite a bit. I'm loving it thus far.
- thedoble
Finished!
This came out awesome, really pleased with it. The fan clips are great - they're VERY snug and the fan goes on with a nice 'click' !
[img]http://i.imgur.com/UuEG40v.jpg[/img]
[img]http://i.imgur.com/t6z0Q8z.jpg[/img]
[img]http://i.imgur.com/VhBRSfe.jpg[/img]
Timelapse of the print: https://youtu.be/6_Ts2lltWGQ (I couldn't get the youtube tag to work)
I'm going to print a 2nd plate for the other side so I can get some nice airflow happening.
Here's the link to the thingiverse download: http://www.thingiverse.com/thing:1248005
- Windshadow
nice work I have yet to try anything that large a clever design as well
Thanks for creating this and posting the files!
gchristopher
Those look very nice!
