Just ran a couple parts with Cura (been using Slic3r), both stand alone, save gcode run through MatterControl.
Part 1:  Test blocks, three 10mm dia cylinder and a 10mm cube, no supports.
   Slic3r:  Cube ended up 10.25x10.24x10.15 (28 minutes)
   Cura:  Cube ended up 10.03x10.02x10.01 (17 minutes)
   Similar result with cylinders.  Cura is much more accurate.
Part 2:  Fairly complex mount for some bearings (small BB-8 internals)
   Slic3r:  gcode:  60mb, est run 6 hrs, 50g material (not going to run this)
   Cura:  gcode:  15mb, est run 1.25 hrs, 15g material, MC bumped hours up to 1.8), took 1.3 hrs.
Main difference is Cura handles supports much more efficiently.  I thought I had similar settings, but obviously Slic3r uses much more material for support.
I'll post an stl at Thingiverse in a bit once I clean the part up and make sure it works.  Thing here:  http://www.thingiverse.com/make:180496
						Cura convert here
Re: Cura convert here
Yeah, between matterslice, slic3r, KISS, Cura, and S3D, you'll find that they each do things a little differently.
Cura is my goto slice, but I do use the other ones for various things from time to time.
