Built an enclosure for my printer, but didn't print out a spool holder beforehand... Forethought and I aren't on speaking terms. So a box and a wifi antenna will have to do until it's done. I'll post up pics of the enclosure once it's done as well. Turns out acrylic is a bitch to cut, so my door panel doesn't have a window, just a hole. Also need to pick up a couple magnetic latches.
[img]https://lh3.googleusercontent.com/-tppa ... 202051.jpg[/img]
Yes, my spool holder receives wifi, doesn't yours??
- barry99705
- thedoble
Re: Yes, my spool holder receives wifi, doesn't yours??
your avatar seems appropriate!
Smoke me a kipper, I'll be back for breakfast.
- barry99705
Started using that back when Netstumbler was still relevant. Was also a Mac guy at the time, so Hexley seemed like a good idea. Been using that avatar ever since! Even had him in my macbooks! Had to pull the display apart to put it behind the apple.thedoble wrote:your avatar seems appropriate!
[img]https://lh3.googleusercontent.com/-VSI5 ... CT0474.JPG[/img]
- thedoble
haha cool!
- barry99705
Kay! Here's the enclosure! Think I need to paint it blue...
From the side as I walk into my office.
[img]https://lh3.googleusercontent.com/-43i7 ... 174252.jpg[/img]
From the front as I spin around from my desk.
[img]https://lh3.googleusercontent.com/-fKie ... 174950.jpg[/img]
With the door open.
[img]https://lh3.googleusercontent.com/-0Gw9 ... 175004.jpg[/img]
I left enough space on the bottom to eventually make a false bottom to bring it up flush with the top of the printer base. Kept one of the cut sheets to use as a pattern. It really helps cut down the noise though!
With the door open.
- Windshadow
very clever and nicely executed
I think your choice of blue would work great!
- thedoble
nice work, the lights are a nice touch
