Tension
DeltaCon
Tension
Post by DeltaCon »
Hi,
I am wondering if my timing belts are too loose. I can easily pull them (all three equally) almost 1,5 cm out of the T slot.
Is that too loose? Is there a way to measure the tension?
[img]http://hennekens.info/rostock/tension.jpg[/img]
Re: Tension
There is no specific tightness parameter and no reliable to measure the tightness. I tighten mine until there is a slight movement when pulled on a they make a low note when plucked.
Yours does sound too loose so I would tighten them up and try to make all three equal.
Threads that deal with belt tightness are here:
http://forum.seemecnc.com/viewtopic.php?f=54&t=2291
http://forum.seemecnc.com/viewtopic.php?f=54&t=1537
http://forum.seemecnc.com/viewtopic.php?f=42&t=1552
IMBoring25
Re: Tension
Post by IMBoring25 »
Where it really matters (like on motorcycle drive belts) they generally use a specific amount of force applied at a specific point on the belt and measure the deflection. Whether it's worth it to go to the trouble to develop that process and the criteria, well...
Return to “Rostock MAX v2”
