New build in progress, which hot end?
AlanZ
Post by AlanZ »
I have just begun building my printer, and am documenting the process on the forum
http://forum.seemecnc.com/viewtopic.php?f=42&t=9622
My first question is which hot end to install at first. I have the stock hot end, and an E3D v6 hot end and mount.
For a first time builder, does starting with the E3D complicate, or simplify getting a new printer up and running?
Thanks for your thoughts.
Re: New build in progress, which hot end?
Simplify in my opinion. The E3D is very easy to set up - no silicones needed. The thermistor is fastened securely with a screw as is the heater cartridge. You can assemble it and start to print immediately since you don't have to wait for silicone to cure. I've never had one fail.
Holy1
Post by Holy1 »
I have only used the stock hotend. I have about 1820 hours on the original Orion hot end without a single jam and still use it daily. I don't have any printing needs over Abs and mostly use pla so haven't needed to change from this simple hotend. I did upgrade to a cartridge heater instead of the resistors right from the begining.
Return to “Rostock MAX v2”
