Easy way to remove ABS joice after print
duvdev
Post by duvdev »
Hi all
I am printing ABS part on ABS juice that I put on the glass.
As you may know removing the juice is a bit hard and messy.
I found out that if you spray some water with spray can as you can find in hair saloon after the glass is cool - leave it for 2 min and them it will come off
as one sheet without an effort.
[img]http://i.imgur.com/CWYPnoh.jpg?1[/img]
Re: Easy way to remove ABS joice after print
Do you putting a layer of plastic or something? It looks like clear plastic cling wrap.
