So got me new part and got my screen up, yay. Moving through to calibration and I can't get my print head to heat up.
The temperature on the head registers roughly room temp, and if I hold a blow dryer on it I can get it to go up and down. So that's working.
I've checked the voltage on the Rambo going to the head and it measures 12.3. I than checked the voltage just past my solder joints at the head. It is also 12.3. I also get the red LED lights to come on as well as my PEEK fan. If I turn off the print head, the voltage drops.
I'm not sure if this helps bit my print bed does heat up.
Voltage to print head but no heat
Benkrygsheld
- Plasticator
Re: Voltage to print head but no heat
You might have a broken hot end heater, or wires that go to the hot end heater. Inspect carefully, and measure the resistance of your hot end heater.
Benkrygsheld
- Plasticator
OK, next question when you say hot end heater where am I placing my leads exactly?
- barry99705
Both sides of the heater resistors. Close as you can get without touching the extruder.Benkrygsheld wrote:OK, next question when you say hot end heater where am I placing my leads exactly?
Solder joints at the head? Where does the manual say to use solder joints at the head?
We need more info and a picture of the wiring at the hotend would be great, we will help you
solve this if you can give us more info on how you wired the hotend and if you are using a heat cartridge or resistors to heat the hotend.
