I bought a Rostock Max V2 around a year ago and it has been fun
My only issue is that each time I swap the nozzle on the stock V2 hotend, I break/damage all the cabling to the hot end.
The printer is currently down due to my latest shorts so I can not print any thing like a new bracket or such.
After my 3rd time damaging it(and blowing fuses due to shorts), I have decided to go with a different Hot end.
I am looking to the other people who have installed a E3D-v6 hotend for some advice on the upgrade process.
Below is what I believe is the process and parts I will need.
Unit to buy = E3D-v6 1.75
What voltage?= Assuming 12v
direct or bowden= Rostock max v2 uses the bowden, so I am guessing bowden is best choice?
URL = Http://e3d-online.com/E3D-v6
Bracket to buy
URL = http://713maker.com/mounts.html
Basic Kit with spacers (over top mount)
Lock Ring =Standard
Spacer Length = 34mm E3D-v6
Instructions to follow to attach and update firmware/printer
URL = http://matterhackers.dozuki.com/Guide/H ... +MAX+V2/25
If any of you have any advice, instructions or recommendations on better suppliers of parts, please reply
Thank you all in advance :>
