3W, 4W, 7W hot end resistors...
djdelorie
Post by djdelorie »
I'm replacing the heater resistors in my hotend, and noticed that there's plenty of space in the pre-drilled holes. I can fit a 4W or even 7W 6.8 ohm resistor in there. Is there any advantage to sticking with a smaller (physically) 3W resistor? Any advice on getting the heat efficiently out of the smaller resistor and into the hot end? The mismatched radius seems like it has very little contact with the aluminum.
DerStig
Re: 3W, 4W, 7W hot end resistors...
Post by DerStig »
djdelorie wrote:I'm replacing the heater resistors in my hotend, and noticed that there's plenty of space in the pre-drilled holes. I can fit a 4W or even 7W 6.8 ohm resistor in there. Is there any advantage to sticking with a smaller (physically) 3W resistor? Any advice on getting the heat efficiently out of the smaller resistor and into the hot end? The mismatched radius seems like it has very little contact with the aluminum.
Do yourself a favor and at least get a ceramic heater cartridge. Better yet just replace the hot end with a E3dv6
If you increase the wattage of the resistor, it won't act as a heater any longer. :)
I would recommend going with a cartridge though - they're very effective. Toss in a threaded thermistor while you're at it. :)
Eric
Post by Eric »
geneb wrote:If you increase the wattage of the resistor, it won't act as a heater any longer. :)
That's not right. The resistance determines how much heat is generated in the circuit. The power rating is how many watts (in the form of heat) that resistor package is expected to dissapate in open air without failing. However, potting in a heatsink can greatly increase the effective heat dissapation and wattage rating, which is why the 3W resistor works at hot-end power levels. If you want to select a different resistor, pay particular attention to the temperature ratings. Generally only some of the wirewound resistors are suitable for hotend temperatures.
I agree with the advice to get a heater cartridge instead.
djdelorie
Post by djdelorie »
An E3D is on the shopping list, but $2 in resistors gets me up and running again. I guess my question was... it seems a bigger wattage resistor is a snugger fit, and would transfer heat better, but a smaller wattage resistor concentrates the heat in one spot (if you pot it right). Which is preferred? Did SeeMeCNC choose a smaller diameter resistor on purpose?
Post by Xenocrates »
I think it was chosen a while ago, back when they still recommended packing aluminum foil around it. I would think that a larger resistor would be better though, as you have less insulation from the RTV. (lower wattages may also have been cheaper)
If you are still using resistors, I have an Edsel automobile I could sell you. :)
nitewatchman
Post by nitewatchman »
Eaglezsoar wrote:If you are still using resistors, I have an Edsel automobile I could sell you. :)
If you really have an Edsel for sale, I really have some money.
gary
Windshadow
Post by Windshadow »
gary
10 to pick from here with a broad range of prices
http://www.hemmings.com/classifieds/?ma ... &year_max=
gary
Just kidding, Gary.
nitewatchman
gary
Just kidding, Gary.
You never know when it may be a Shelby in a barn.
Return to “Rostock MAX”
