Faster Heated Bed
Check out how others are building and modding their own heated beds
KAS
Re: Faster Heated Bed
Post by KAS »
I cant see your image above, but I have mine wired a bit differently from your description. Although I'm not sure that would effect your F3 fuse.
Can you post a picture of your install?
On mine,
power supply negative to Crydom 1, Crydom 2 to Onyx negative.
Power supply positive straight to Onyx positive.
Larger image for a better look : http://forum.seemecnc.com/download/file ... &mode=view
[img]http://i482.photobucket.com/albums/rr18 ... 200413.jpg[/img]
Jrjones
Post by Jrjones »
ignacmc wrote:Hello to all
I have wired my SSR (Crydom D1D40) as per gchristopher schematics:
[img]/Users/ignacmc/OneDrive/3D PRINTING/24V PSU - SSR/24v_upgrade.jpg/[img]
But when I switch on the printer F3 fuse blows...Any advice?
Thanks in advance
For sharing your onedrive pics, right click the image and select "Share a onedrive link" like here:
and paste it into whatever: https://onedrive.live.com/redir?resid=E ... hoto%2cjpg
Fuse F3 controls the logic, hot end, and fans. Is it possible you dropped a wire or something else conductive on the rambo board causing a short somewhere?
ignacmc
Post by ignacmc »
Thanks everybody for your help and sorry for not answering earlier. I was busy and a bit tired of fighting with the electronics issue
I have wired the SSR following KAS instructions...And I seems to kinda work but the following happens:
If I measure voltages at the exit of the 24V to 12V converter with the RAMBo board power plug DISCONNECTED, everything seems OK: 24V at the input and 12V at the output. The Crydom SSR is connected and it reads 24V between 1 and +2 (Open circuit) and 0V between 4 and +3 (normal since the RAMBo is unplugged.
Now I switch everything off, I connect the power Plug to the RAMBo and kick the switch on. What happens now? Well, everything seems to work, including LCD and heated bed, but I notice that if I measure the voltage at the output of the converter and in the RAMBo Power Plug I obtain 24V now!!! The board is being fed at 24V!!!!
Why the F3 fuse does not blow now? Because I changed it to a 10A unit instead of the original 5A, so it seems to be able to withstand the increased current that results from being fed at 24V. That's why I am able to measure the voltage this time and not the times I tried before when it blew instantly....
What I am doing wrong? Where can the extra 12V come from? The converter seems to work ok while the RAMBo board is not plugged...
Please help...I am getting really desperate with this
Eric
Post by Eric »
Remember we're still going solely on your words, and haven't seen the image you tried to post. Perhaps if you tried again to post your circuit diagram? Or pictures if that would show the details of your wiring setup. Or both?
The logic and LCD work because Rambo has a 5V regulator on the board, which has no problem with 24V instead of 12V as input. But the fan and hotend outputs would be seeing the higher voltage if what you say is right.
Tincho85
Post by Tincho85 »
The Rambo board is being fed only by the step down converter?
It's a DC/DC converter? how many amps can it handle? Maybe it can't handle the load so that's why it delivers 24v when working.
Share a picture or diagram of your connections when you can.
Martín S.
ignacmc
Post by ignacmc »
Hello to all
This is my setup:
[img]https://onedrive.live.com/redir?resid=9 ... =folder%2c[/img]
And the DC converter is a 30A one
ignacmc
Post by ignacmc »
KAS
Post by KAS »
What is the brand/model of the dc/dc converter?
ignacmc
Post by ignacmc »
I have tried several:
the first only 10A and got overloaded
The second one is:
Xincol DC 24V to DC12V Big 30A Voltage Reducer DC/DC Converter
http://www.xincol.com/product-detail/dc ... nverter-2/
KAS
Post by KAS »
Please post a pic of your setup. Hard to work through this without a visual.
nitewatchman
Post by nitewatchman »
To me the wiring sketch you posted looks okay and is basically how mine is connected. One question however is on the 24VDC to 12VDC converter, how did you handle or connect the magic yellow wires?
Looks like on the 24VDC side connect the yellow to the red but on the 12VDC side the yellow should just float or be cut.
gary
ignacmc
Post by ignacmc »
Yes, I connected the yellow to the red in the 24V side and left it unused on the 12V side...
ignacmc
Post by ignacmc »
I even disconected yellow from red on the input, but the same keeps happening:
INPUT: 24V
No load OUTPUT: 12V
With Load OUTPUT: 24 V!!!
I am trying tonight using the previously unused yellow wire on the OUTPUT. But the converter instruction clearly say it does not need to be used!!!
Looked a simple thing in the beginning, but this is driving me nuts! :oops:
Tincho85
Post by Tincho85 »
Contact their customer support, it looks like a faulty step-down.
If not, they might tell you what's going on wrong.
Martín S.
Tincho85
Post by Tincho85 »
Guys I need help asap, I think my SSR have just failed...
When I turn on the printer the bed temperature keeps rising by itself.
* It's a 100a Fotek.
* It' has never gotten hot when operative.
* No signs of a burnt.
* There is no light in the SSR.
How can I tell if the SSR is failing? maybe fix it?
EDIT: moved to a new thread:
http://forum.seemecnc.com/viewtopic.php?f=37&t=10744
Martín S.
DeltaCon
Post by DeltaCon »
I took Tincho's picture from the OP because that's what I used to upgrade my Max V2.
I made 2 additions:
- I have a Crydom D1D40 instead of the (ill advised) Fotek, and my Onyx heated up directly after switching on the whole mikmak. Better looking I found that the plus and minus on the output side are reversed compared to the fotek. Switching the wires resolved the problem. I have been heating the Onyx to 90C for a minute or 20. It gets the temp up dramatically quick (with the voltage of the PSU set to the minimum of 20,5V, I can't turn it lower any more than that). This SSR does not get warm at all! I strapped it to the metal of the PSU thinking it gets a bit better cooling than none that way.
- I read elsewhere that an inline fuse is advised. I found the one I added in the picture below. Looks nice and you can stick it in a hole in the base for easy changing (although the base will most likely have to be opened up if the fuse fails anyway...) What Fuse should I use. 30 Amps? Perhaps 25 would be sufficient, but I guess if the Onyx shorts that makes no real difference if a 25 or a 30A fuse gets burnt.
I also added a switched external receptive for a regular powercord. One that is fused 10A on the 240V side. And added a 8cm PC casefan to the base to get some airflow around the stepdown converter. But apparently that does not get warm too. Nice effect of the stepdown is that it gives out 12,5V (?) very rock-solid. Heating the hotend does not even give a fluctuation in the output voltage (anyway not measurable with my multimeter set to 1 digit behind the dot).
I have a Delta Electronics PSU with a noise fan (they all seem to have that). But it only turns on when a significant load is... loaded. It only turns on when the Onyx LED is lit (and the bed heats of course) and immediately shuts off when PWM switches the bed of. That is very annoying but I hope it won't be anymore when the base gets closed again.
So, my original on/off switch is not used anymore. Can someone think of a nice repurpose of that? I would be nice to have some emergency power off or something ;-) I could use it to switch the 12V circuit but I am not sure that makes sense...
Thanks for this great guide! It was very helpful.
Post by Xenocrates »
I can think of a few. Have it switch control to the SSR perhaps? Another option is to replace it with an illuminated power indicator, or perhaps a pair of them (in a nice 3d printed bezel, of course), to tell you when it's got power to either the Onyx (If like me, you have a heatspreader that blocks the LED), or the primary system, when there's 12v system power, or when the hotend is actually heating.
DeltaCon
Post by DeltaCon »
Yes two leds for heating hotend end bed would be nice, perhaps combined with a system power led. Could I simply put leds parallel on the heater outputs of the Rambo, or would pwm kill them?
Still I would like to have an emergency switch, on that kills all heaters and motors but keeps the peekfan running. Someone ever did something like that? It would be super to have a sensor kill the 240V input power when temp inside the base raises to say 150C, because that would mean serious problems, perhaps fire.
But to get realistic again: what fuse do I use to protect the bedheat circuit on 20V? ;)
DeltaCon wrote:Yes two leds for heating hotend end bed would be nice, perhaps combined with a system power led. Could I simply put leds parallel on the heater outputs of the Rambo, or would pwm kill them?
It would be more likely that the voltage would kill them. You would need a current limiting resistor like is used on the Onyx itself, and the value of that is dependent on the LED in question (so I can't tell you that bit). As far as sensors to cut power go, I have a 25A relay that cuts heated bed power when a thermal fuse under the bed blows (this requires replacing the thermal fuse each time, only cuts the bed power, and is tied to the bed temp rather than anything else, but similar approaches can be taken elsewhere, like what the HE280 uses). Killing the heaters and motors while keeping the fan running is difficult. You would likely have to have a 3 contact contactor (IE, capable of handling 20+A's) relay, and have the heated bed, motor power to the rambo, and heater cartridge power out of the rambo (As killing it before the Rambo would kill the fan too, unless it was wired straight to the power supply).
For protecting the heated bed circuit at 20V, that should see a draw of 20-18A, so a 25A fuse may do it, although unless you actually sink the fuse thermally, a 30A is likely better.
JaseGillUK
Post by JaseGillUK »
Hi all,
Long time reader, first time poster here. I built my V2 only around 4 months ago but took this long to sort out a faulty log in here.
I also want to upgrade to a faster heating bed so the 24V route seems to be the right one.
To do that I have bought a 24V 25A 600W PSU, a 24-280V 40A SSR and some 10AWG cables as well as an inline fuse.
I have also bought a 24V Onyx (Rev3) bed, a thermistor for it and some 3mm LED's (figured a few just in case).
As I am in the UK and getting supplies is often an issue (postage is a killer given Brexit and £/$ exchange rates) I also bought the HE280 and cable loom for it as it made sense to get stuff in bulk - thats all for a later Print Head update even though I love my current E3D-V6 and 713Maker mount that was my 1st real upgrade step.
So my questions on the 24V bed upgrade are these:
1. Do I need to use a 24V bed here? It seems a lot of folks are using their standard 12v one and just upping the PSU voltage input?
2. if I use the 24v bed I have the aforementioned 24v 25A 600W PSU. What size resistor should I solder to the bed for the LED? I'm Ok doing the maths but get lost as to which bit of maths is the right one so any pointers would be very useful.
Thank You,
Jason.
JaseGillUK wrote:Hi all,
Thank You,
Jason.
1. Nope. the 24V bed Seeme sells sits in between the 12V and the 24v operated versions of the normal one, which makes it less of a bear to source power supplies for. You can (And may want to) use that, since you have it.
2. Assuming that the LED is designed for a voltage drop of ~1.8 (Common for red LEDs), you would need a resistor that is 750-820 ohms, and ~ half a watt. Something like this would be perfect. See if you can't find a nice electronics store around you that sells components, otherwise it's unlikely to be worth ordering in case you blow the LED.
JaseGillUK
Thanks Xeno,
Thats what I thought.
The resistor I had in mind is in that range too.
I just wanted to make sure I don't blow anything and check my understanding.
626Pilot
Post by 626Pilot »
Does this look right? I'm using the old 450W Viotek power supply, using the SSR to bypass the MOSFET on the controller because the plug gets hot. I'm using three each of the + and - wires from the PSU.
PSU +12V to Onyx + through a wire nut
Onyx - to SSR +
SSR - to PSU Ground
Is that wire nut OK, or is it going to give me trouble?
626Pilot
Post by 626Pilot »
Also, is this 25-amp DC breaker good enough? https://www.amazon.com/Blue-Sea-Systems ... eaker&th=1
I used an online calculator to figure out that 24V @ 1.1 ohms is a little over 20 amps. Should I go higher?
626Pilot wrote:Also, is this 25-amp DC breaker good enough? https://www.amazon.com/Blue-Sea-Systems ... eaker&th=1
It's about right, as breakers/fuses should run at at most 80% capacity. I might over size it a little, but there's other voltage drops which will drop the amperage slightly, so don't worry too much (I just overbuild things). For the SSR' it's hard to tell, but if that single wire is coming from the bed as I think it is, it's fine. (I made a mistake in the polarity myself and toasted one, but hey, the terminals are cool. I just need to finish prying them loose).
Return to “Heated Bed How-To's”
