Options for Upgrading my Ezstruder?
cpu77
Post by cpu77 »
I want to replace my stock Extruder setup with a all metal extruder with a geared motor. I want something thats kind of a drop in for the most part. So far I have looked at....
MICRON 3DP
Bondtech QR
Bulldog Extruder
Does anyone have any opinions on these or any others not listed?
Thanks Ralph
Re: Options for Upgrading my Ezstruder?
I'm designing one that fits the bill, but I don't have the files finished yet.
+1 for BondTech, from what I've heard and seen. They're quite nice.
cpu77
Post by cpu77 »
I can't wait to see what you have. I think I follow you on Thingiverse;)
I own the Bondtech QR and it is without reservation the best extruder on the market.
enggmaug
Post by enggmaug »
But QR is not all metal... as it seems to be one of the requirements....
cpu77
Post by cpu77 »
Well guys.... I dropped the all metal part:) I went ahead and bought a Bondtech. Thanks for helping me out. Is it silly buying parts for my printer makes me giddy? What do I need to mount it to my Rostock Max V2? I would like to have what I need when it shows up.
Post by Xenocrates »
The Bondtech site has STL's to mount it to a Max, so you can print them yourself (I presume you did not buy the mount along with it, since you're asking). You probably will want heat set inserts as well, since the mount is designed for them. I believe many hobby and hardware shops should have them. You could also print out the basic fixture, and attach it inside the top deck, feeding through the little hole there, if you have a chamber. (I haven't got one of my own yet, because I'm a poor college student, but I've been planning out how to mount one when I get it)
cpu77
Post by cpu77 »
I actually printed the mount and it came out great. I am going to Fastenal today to see if they have the brass inserts. I did find them at Mastercar. I am listing part numbers for others.....
91292A124
Type 18-8 Stainless Steel Socket Head Cap Screw, M5 Thread, 10mm Length, 0.8mm Pitch, packs of 100
94180A361
Metric Brass Heat-Set Insert for Plastics, Tapered, M5-.8 Internal Thread, 6.7mm Length, packs of 50
Thanks for posting this information and I like the way the mount came out.
Return to “Rostock MAX v2”
