In the last few weeks I really tried hard to find a affordable printer with a bigger buildvolume than the Max2, esp. in diameter.
Indeed there are some interesting models, but all of them are in a price range near or over the frontier of 10.000$. I think they are worth every penny, but for many of us not affordable.
So why not doing it ourself, as we do always.
My intention is now at the first stage to gather ideas to create a imagination how this fictional printer could look like. Completely fictional specification.
The only frontier is the amount of money, 3000$
Build Volume :
- min. 400mm to max 500mm in diameter ?
- height can be flexible, but maybe it is an issue of rigidity? For me 1000mm shell be enough.
Structural issues :
- high rigidity for the frame and for the arms
- high flexible joints but with minimal tolerance and high stamina.
- Heat chamber
- Extruder right on the print platform for optimal filament feeding
- Heated printbed with sectoral heat areas (energy saving measure)
- Flexible use cases for the print platform (milling, printing, etc...)
- separated electronics
Electronical issues :
- Controller with a higher CPU performance for better print performance
- USV will save your print in case of energy loss
- Pause and resurrection function
- Plane function (to recreate a failed print)
- Stepper motors with higher torque, because aof a heavier printplattform, and for compensation higher lateral acceleration and inertia.
- SD Card printing
- Open source electronics
- Webcontrol
Constructural issues :
- brouder belts to stand the higher torque
- coated nozzle to prevent clogging (teflon etc....)
- Adjusting ballbearings, to keep the belt on position, similar to the old transmission belts in the history of industry (If it works)
- flexible tube to cool the stepper motor of the extruder and the extruder itself in the heat chamber
- If possible the most moving parts shell not inclosed in the heat chamber, to avoid material stress which will prevent loss of precision.
- preciscly guided channel for filament refill near the stepper motor
- Bouden tube shell be inclosed in cooling tube for the extruder cooling to prevent filament weakening
Print issues :
- same precision as the Max2 in x and y, maybe a bit better brought about tighter arm an skates construction ?!
- Same z height capabilities
- Nozzle size from 0.35mm to 1mm
- Printmaterial : ABS, PLA, Nylon etc... most common materials
- 360° print area cooling, for a constant shrinking.
Software issues :
- firmware ???? I dont have any clue about such things
 - Webcontrol
- Webcam
- Time lapse shooting
Safty issues :
- fire fighting device, print erea and electrical erea.
- covered moving parts to prevent injuries
- electrical parts covered to prevent electrical shocks
- 12 Volt to prevent life endangering electrical shocks
Allright my brain is empty now.
Maybe you have some ideas or objections, so feel free ....................
