Check it out here:
https://docs.google.com/spreadsheets/d/ ... sp=sharing
Wish me luck!
The plastic would be pulverized, and I had thought it would only really need to be heated at the very end, please correct me if I am wrong. Also why would you prefer a taper bearing?also feel that a single heater may be insufficient and sub optimal. I would prefer to have them designed so as to have control over the temp at multiple areas along the extruder, even if it raises costs
Any way you could sketch a quick diagram? I think I see what you mean just not quite sure. The explanation makes sense.Xenocrates wrote:Personally, I would run three heater bands on it, to make it easy. Main heater connected to the PID module on it's own. Two others in series with each other (and parallel to the main heater), with a smaller gap between the middle heater and the main one as compared to the middle and the end heater. That way your temperature comes up sharply at the end, you don't need any resistors to dial down the heat on the one that isn't at the end of the barrel.
My apologies, the mechanical was what I had questions about. That makes a lot of sense. I will update this thread with CAD files by the end of this week to clarify some things.Xenocrates wrote:You weren't too clear about which diagram you wanted, so I drew both a physical (Showing approximate placement), and an electrical, showing wiring placement. Note that the numbering is consistent. Of course, there is no real reason to wire H2 before H3, it might even make more sense to wire H3 before H2, so as to reduce the amount of wire near the barrel. depends on you.
