Hey Guys, Been a while since I have been in the forums. I'm having a strange issue. Printer has been running pretty good but last month I went to print something and discovered all setting were gone. Print time and filament used was zeroed, Z height and all tower adjustments were lost, everything. I haven't changed anything, it was just gone. So I went through the process of clearing the Eprom and loaded up .91S. Did all the PID adjustments and Z height, horizontal radius adjustments etc. Got it running again BUT THEN today the same thing happened, everything is gone! Any ideas on this one?
Kris
Loosing all settings
Re: Loosing all settings
There was an example on the Forum of something similar and the fix was to change the baud rate in the eeprom from 250000 to 115200, and adjusted Repetier Host to match. Now, M205 returns perfectly now everything works.
Try turning down the baud rate, you may have to use a backup of the EEPROM after changing baud rate. I know it doesn't make much sense except that this worked for one individual. Let us know if this helps.
I will give that a try. Although seems odd that the printer has been running for over a year with out this issue till now. I'll report back.
