No solder joints on back of the LCD
leafi
Post by leafi »
Hey everyone
Does anyone know if there should be 2 connections on the back of the LCD (one on each of the connectors) which are not soldered? Ill try to post a pic later if you dont know what I mean.
Thanks
cambo3d
Re: No solder joints on back of the LCD
Post by cambo3d »
yes post a picture, all of the connections should be soldered on the back of the lcd where the connectors go. Possible that you might have a bad lcd which I had myself.
leafi
Post by leafi »
Ok Ill take some tomorrow when Im back at work. It wasnt even cracked joints, there just wasnt any solder at all it was clean.
leafi
Post by leafi »
well I took pictures on my phone. IN the pictures I could see what looks like solder in the thru hole but it did not wick up the pin or break the surface. I guess the bottom side of the card was wave soldered however that is a really poor solder joint.
http://s1018.photobucket.com/user/Le_AF ... sort=3&o=0
cambo3d
Post by cambo3d »
have you tested it yet. does it work?
leafi
Post by leafi »
No I am rather far from that step. I only have time on the weekend to build it so I had to stop on Sunday. Part of me is thinking that Im never going to get this thing working right but Ill give it my best.
cambo3d
Post by cambo3d »
my replacement lcd from seemecnc didn't look like all the solder joints were soldered either 2 were suspect but i don't know if that matters.
what matters is the lcd powered on and displayed properly which it did.
Return to “Rostock MAX”
