MAX METAL poll -build right or upside down?
- bvandiepenbos
How are you building yours?
Re: MAX METAL poll -build right or upside down?
Opting for "normal style".  I don't want my printer to be top heavy.
If you mount your power supply to the base, that'll solve the "top heavy" problem.
							Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
Duet v.8.5.0
I ended up moving the PSU completely outside the enclosure bc prevent overheating.
What's the advantage of flipping it upside down?
Update:. Ah I guess it would make wiring easier. Too late now.
I ran some of the Trick Laser 8-conductor wire up one of the insides of the channels. That takes care of the endstops. For the hot end wiring, I use a cable mast: http://www.thingiverse.com/thing:1554882
