I've got one of the new Power Supply (the new industrial one) but the fan noise is very loud when on. I was wondering if anyone has ever replaced the fan in this and if so does any one know what size of fan I would need to get to replace it?
Cheers
						Power Supply Fan Size
Re: Power Supply Fan Size
Sorry, but apparently no one has had to replace that fan.  I recommend that you unplug the power supply and remove the screws holding the
case closed and measure the fan before ordering one. Best of luck and if you don't mind would you let us know what size the fan is?
Got around to doing this this weekend. For people looking to do this with the newer powersupply it's a Doceng 60mm x 60mm x 15mm fan in mine. I stumbled across and ordered one that should be 16db on full chat, should fix my noise issues nicely if it works....
Just to note, a 60x60x25mm fan does not fit. the case doesn't close as the fan is too fat.
Wonder if a noctua one would fit.
Had good luck with one of those on the rambo
It would fit only if it is 60x60x15mm. I share your respect for the Noctua fans.teoman wrote:Wonder if a noctua one would fit.
The best fans made.
That's how I know a 60x60x25mm wont fitteoman wrote:Wonder if a noctua one would fit.
 I tested it with the one I bought to replace the exhaust fan. They don't do a 60x60x15 version unfortunately.
 I tested it with the one I bought to replace the exhaust fan. They don't do a 60x60x15 version unfortunately.Re: Power Supply Fan Size
Thanks for sharing. I do not have the new power supply but if i do get a max v3 some day, you saved me some time.
No love for sunon maglev fans anyone? I really like those fans. Quiet.
							Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
Duet v.8.5.0
I was just wondering whether it actually worked to make your Max3 significantly quieter?
tia, beat
						tia, beat
Not sure if its the same PSU on the V3, but worked a treat on my V2 power supply. Loudest part on mine is now is the heatsink fan.
