Bowden tube Slippage
So i'm noticing the bowden tube is slipping on my printer, on the extruder side connector. It moves up about a centimeter with each motion, meaning my retraction isn't actually doing any retracting. Do i need to cut off a small bit of the tube on the affected end, or replace the connector, or what do i do here?
Re: Bowden tube Slippage
Give this a shot:
http://repables.com/r/444/
Tried it. Couldn't get the affected side of the bowden tube out of the locking mechanism. Put the clip on both sides, no difference, the tube slides about a half centimeter to a centimeter within the tube, throwing off retraction.
Sounds like a blown fitting to me.
- Windshadow
+1 if it slips when locked with the printed lock than the fitting is no good and must be replacedgeneb wrote:Sounds like a blown fitting to me.
